We value your input!
Roof Pet Palette editing commands not comming up
Hello
I need to customize a roof, but It wont let me edit it with any of the options that normally come up in the pet palette are not available.
you can see in my pictures whichones I mean, the firts option: "stretch horizontal ridge", "Drag horizontal ridge" and so on... I only get the normal drag, rotate, mirror, multiply commands. .. I tried redrawing the roofs again but this doesnt change..
Is there some other way of getting these commands? or how can I fix this 😕
5 REPLIES 5
Lingwisyer
Guru
That roof is not grouped with anything is it? If so toggle grouping.
Also, the options will only appear on node selection, when there is a tick next to the cursor.
Ling.
Cohenm
I am having the same problem with AC 25. On some roof nodes the stretch/drag horizontal ridge commands appear, and on some they do not. Has anyone found a solution?
Hi @Cohenm
That sounds rather like an irregular behaviour. Did you report it to your support team? They can try replicating and detect whether it's a bug.
Gordana Radonić
Community Manager
Hi @Gordana Radonic,
Do you mean emailing support@graphisoft.com?
Hi @Cohenm, is your local Graphisoft support our North American team?
https://graphisoft.com/us/contact-us/local-contacts
If so, I believe the email is  support.na@graphisoft.com
Let me know if you need other information!
Gordana
Gordana Radonić
Community Manager
