Roof Windows/skylights
Is there a way to label Archicad12 standard Skylight object (Skylight top hung) and put them into a schedule. I was thinking there should be an option to add a window marker and a parameters for listing section too for a schedule. Is this the typical object that is used or is there another one I should be using to get the outcome I want.
Thanks
John
1 REPLY 1
in AC13 you can have multiple element types in a schedule. Windows and Skylights can be scheduled together based on their ID's. However, the marker will need to be manually drawn still.
