Tom Krowka
Roof edge question
I have a roof that is 9" thick. When I select the edge of the roof, I can go to the roof edge command that allows me to change the shape of the roof edge. However, HORIZONTAL is greyed out. That's the one I need.
How can I activate that selection?
Tom Krowka Architect
Windows 11, AC Version 26
Thomas@wkarchwk.com
www.walshkrowka.com
9 Replies 9
Erika Epstein
tom,
I am guessing that you are trying to do this on the rake edge. In this case it is greyed out as a precaution because making this edge horizontal might cause an invalid polygon.
I am not sure what you are trying to accomplish. You could type in a custom angle of 0º; the result would give you a roof plane of no thickness.
so.. what are you trying to do?
Erika
Architect, Consultant
Mac OSX 10.11.1
AC5-18
Onuma System
Ben Odonnell
Tom,
It depends on what roof edge you are trying to apply the command on, please see attached image.
HTH.
Cheers.
Ben
Ben O'Donnell
Link
Only the edges that are parallel to the pivot line have this option.
Link.
Ben Odonnell
Thanks Link,
I forgot to mention that
Ben O'Donnell
Newbie... believe I have the same problem (see image). Even if it's not the same problem, a problem nevertheless
Erika Epstein
Looks like you have a composite selected for your roof. This pre-determines the roof thickness.
If you want a different thickness for your roof pick
-a composite that is the correct thickness or
-modify your chosen composite or
-choose a non-composite which will allow you to set the thickness where you indicate in your jpg
Erika
Mac OSX 10.11.1
AC5-18
Onuma System
Looks like that to me, too, Erika.
This is a good usability one for the wish list. Most of us old-timers don't think about the fact that composites affect roof, wall or slab thickness, for example. (In fact, we count on it.) But, I wonder if it wouldn't help newbies if a little bit of text (or something) showed up next to the entry fields when a composite is selected that says something like "Depth defined by composite".
Well, that wasn't exactly user friendly ... anybody have a better proposal and think it is a useful wish for making AC easier to learn?
(I suppose the next step would be a button that let you jump right to the composite definition if you wanted to change it...)
AC 29 USA and earlier   •   hardware key   •   macOS Taho 26.5 MacBook Pro M2 Max 12CPU/30GPU cores, 32GB
Erika Epstein
Spoiling the Newbies again Karl?
Erika
Mac OSX 10.11.1
AC5-18
Onuma System
I'm all for being spoiled
PS: Thanks!
