Roof intersection
Hey,
I'm trying to connect 2 roof elements together, that roof hatch would be properly shown on this section view (see attached image below). Left roof is one element (0°), the right one is part of complex roof. I tried with SEO, but the result is not what I want. Any clue?
Thanks in advance ,
Rok
5 Replies 5
Dontknow
Draw both roofs through each other and then use 'Trim Elements to Roof/Shell' to trim both roofs to each other.
First select the roof you want to trim, then select 'Trim Elements to Roof/Shell', then click on the plane of the other roof and then click on the part of the roof which you want to keep.
Architectural construction designer, draftsman, modeller
ArchiCAD 25.
Dontknow
Here is where you can find 'Trim Elements to Roof/Shell'.
ArchiCAD 25.
Dontknow, thanks, it works like a charm
David Maudlin
This command is also available via the context menu: Connect > Trim Elements to Roof/Shell.
David
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
Dontknow
David
True. All buttons can be find in the menus.
ArchiCAD 25.
