Roof light opening in roof accessory library part
Hello again!
Putting a roof light into a roof that has had a roof accessory added in the form of spanish tiles, it seems the only solution is to SOE the roof accessory library part with the window to get an opening
Is this the case? seems a bit naff...
Also is there a link somewhere to latest Velux products as GDL objects?
many thanks
Paul
18 REPLIES 18
NCornia wrote:
Perhaps we should all send Eptar an e-mail stating they should make an English translation of their products for wider use.
I agree.
NCornia wrote:
You can get a better idea of what is on the site by using Google's translator http://translate.google.com The translation is not perfect but it helps to get some of the language across.
I not agree. It will not translate correctly the terms.
NCornia
Good news. Eptar replied to my e-mail with news that they are already working on an English site and products in the English language.Should be ready this summer if not by June.
Thry sent me some YouTube links that demonstrate some of their products in English.
Movies about:http://www.youtube.com/watch?v=i-5QigfrU2c (2 min)http://www.youtube.com/watch?v=62OGlVnqHV4 (12 min) - userguide Userguide:http://www.eptar.hu/download/eptar_bemutatkozo/roomtiling_userguide.pdf
Nicholas Cornia
Technical Support Team - GRAPHISOFT North America
ARCHICAD on Twitter
Tutorials
GRAPHISOFT Help Center
vistasp
I've tried their tiling addon in Hungarian but:
(1) Major language problem!
(2) It only worked with 32bit AC
(3) I think the tiles were limited & manufacturer specific but then I could well be wrong because of point (1) above. 😉
= v i s t a s p =
bT Square Peg
https://www.btsquarepeg.com
| AC 9-27 INT | Win11 | Ryzen 5700 | 32 GB | RTX 3050 |
I hope Eptar will keep his promise to provide you an English version, for all add-ons they have on site.
I understand your problem, I would be in the same situation if an add-on were in Indian
Regards, Ede
NCornia wrote:
You can send Eptar an e-mail here: info@eptar.hu
Maybe if they hear from more of us then they might take action.
Done
What is known about Eptar? The English version off add-on is ready and available for download? If so, for what version of AC is available?
No one knows?
There are some for AC 15, but I didn't saw any English version.
Regards, Ede
the Romanian version of VELUX CAD available at VELUX Romania.
regards,
