Roof modelling issue
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
2007-09-26
03:43 PM
2023-05-23
03:15 PM
Rubia Torres
2007-09-26
03:43 PM
1. I have to model a roof with polygonal edges. I modeled the underside of the roof with the mesh tool.
If I use the mesh-to-roof tool, I will get a roof with the upperside in the underside position and is not ok.
I tried with the 3D approach. I modeled the roof in 3D but the same problem appears.
Is it possible to modify the reference plane of a roof?
2. How can I draw a roof with more than 90 degrees slope. That is, inverted.
arch. ernest atanasiu
AC 10-26 INT/GER/FR on Win 10/ Win 11
6 REPLIES 6
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2007-09-26 03:44 PM
2007-09-26
03:44 PM
pic 2, problem 1
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2007-09-26 03:44 PM
2007-09-26
03:44 PM
pic 3, probl. 1
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2007-09-26 03:45 PM
2007-09-26
03:45 PM
problem 2
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2007-09-26 06:59 PM
2007-09-26
06:59 PM
uisanata wrote:You said that it is not okay to get a roof with the upper side in the underside position. I agree. What is down is up.
Actually I have 2 problems.
Why not, if the modeling is correct, invert the materials?
OR, instead, make a complex profile wall at the angle you need.
Stay away from mesh for roofs. Mesh bad.
Dwight Atkinson
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2007-09-26 10:08 PM
2007-09-26
10:08 PM
I want the underside of the roof to be in the actual position of the mesh. Everything I've tried does the opposite: it generates an inverted roof whose planar projection is ok but the materials are on the other side. So I can't calculate room clearance on the inside of the building correctly.
I have to use the mesh, because the roof is very irregular. A solution could be to remodel the mesh in the position of the upperside of the roof and then generate the roof.
I don't know about the slanted wall method. I know only the position of the mesh in 3D. How can I model all the walls in the correct position?
And, yes, the solution with changed composites seems the correct approach.
Still remains the problem of generating the roof first.
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2007-09-26 10:37 PM
2007-09-26
10:37 PM
You must study "Complex Profiles" to make slanted walls.
Dwight Atkinson
