Roof plan question
Is there a way to generate a 2D vector line roof plan in Archicad? I used the top view axonometric window which is exactly what I wanted - but it's a bitmap. The reason for doing this is to import the drawing into Autocad. Thanks in advance for your help.
13 REPLIES 13
Link
You simply need to go to your roof story and save a DWG from it.
Link.
Thanks Link - I tried that; however, the roof plan is still not accurate. I guess I need to trim the roofs at their intersection points to get an accurate 2D roof plan. I've tried to get the roof edge trim pet pallette to pop up to no avail. Is there a way to trim roofs? Thanks
Dwight
we should see this - it is unusual.
Dwight Atkinson
Dwight and Link,
I solved the problem by using the top view axon with hidden line function enabled so I could see where the roofs intersected- I then added hotspots to edit the roof forms. You both probably already knew this - my firm is autocad only and I pick things up any way I can. I tried to make a PDF to show you but it didn't work. Thanks for your help.
Dwight
Carry on as a champion of Archicad.
AutoCAD. I remember my old firm. I would take projects home and draw them in Archicad over the weekend and return on Monday with perspectives.
You will eventually knock them dead.
Dwight Atkinson
Link
You need to learn how to join roofs properly. Try selecting one roof and then ctrl clicking the edge of the other roof and it will extend or reduce to meet the plane of the selected roof. Then you need to repeat the process with the other roof. You can do all of this in the 3D window too, which is often easier to see what you're doing.
I'm sure it's detailed in the reference guide too. Surely...
Link.
Aussie John
if you still wish to create the vector lines from the top 3D view save as "2D lines" once in the 3d window
Cheers John
[/size]
Steve Jepson
Using the Internal rendering engine in Hidden Line mode, just surround the view with you want with the marque tool ( last marque option on the right) Copy, and Paste it into your AutoCAD. Or you could paste it into your ArchiCAD floor plan and Drag-n-drop it into AutoCAD later when you have it finished.
Link
What's all this talk about saving the view from the 3D model? That's the WORST advice! Unless there are major SEOing, this is clearly not the best route to take.
It's simply a matter of modeling it correctly and saving a DWG from the roof plan!
Link.
