Roof won't repair itself when skylight erased.
Hi Forumites,
I have placed a series of skylights in shallow pitched roof (1/4"-1'-0") and decided that they needed to be reconsidered. When I erased the skylight I fully expected the roof to heal itself. It did not.
The roof is a thin (1/2") ArchiCAD roof with a Cadimage steel deck over it. Any ideas on what the problem seems to be?
Thanks in advance.
3 Replies 3
Brad Elliott
I haven't seen the problem but you should still be able to delete the hole. Can you do that?
Mac OS12.6 AC26 USA Silicon
M1 Macbook Pro
Thanks Brad,
I used the "add polygon" command from the pet palette and the hole was fixed but I still don't know why it wouldn't repair after deleting the skylight. Any other thoughts out there?
Link
My guess is that the CadImage add-on has altered the roof's functionality.
Link.
