2010-01-08 10:32 PM - last edited on 2023-05-23 02:58 PM by Rubia Torres
2010-01-11 11:05 PM
Peter wrote:Nice tip Petermc0m wrote:It will still work. You just need to make sure the beam has a higher priority number than the wall, then SEO as normal. For example if the wall is 8, then the beam needs to be 9 or higher.
On the other hand, I need for the pitched element to do an upwards extrusion of the wall that it is resting on. That was a very straightforward SEO when the element was a roof. Now it is a beam, and they have intersection priorities which are odd numbers. The intersection priorities of the wall are even numbers ... so the SEO can't happen.
It may not be working at the moment because the wall could be automatically cutting the beam away leaving nothing to SEO.
2010-01-11 11:17 PM
Markus wrote:No problem, I'm glad it's useful!
Nice tip Peter
I hope I see you here often. Thank you every time for your help.
