Rotating a roof with 2 pitches?
Im fairly new to ArchiCad and was wondering if there is a way to rotate a single plane roof in two directions?
1 Solution
A roof plane can only ever pitch in one direction, however the pitching line can be at an angle to the front of the roof so it appears to be pitching in two directions.
See this post and follow the links for more info.
https://archicad-talk.graphisoft.com/viewtopic.php?f=22&t=66929
Go to post
1 Reply 1
