‎2007-08-2801:44 AM - last edited on ‎2023-05-2305:06 PM by Rubia Torres
‎2007-08-2801:44 AM
How do I rotate a slab around the x axis? For example, I have created a corbel with a complex profile using the slab tool but it needs to be rotated to be in the correct orientation.
While I agree that that "info's" object could be done either way, the limitation of complex profiles is that the cross-section remains constant throughout the object. Whereas, the "slabify" and building up of an object allows you to create a fairly complex GDL object of disparate pieces, regardless of the rotation issue.
Richard -------------------------- Richard Morrison, Architect-Interior Designer AC26 (since AC6.0), Win10
