Rotating an object around the x axis
How do I rotate a slab around the x axis? For example, I have created a corbel with a complex profile using the slab tool but it needs to be rotated to be in the correct orientation.
10 Replies 10
While I agree that that "info's" object could be done either way, the limitation of complex profiles is that the cross-section remains constant throughout the object. Whereas, the "slabify" and building up of an object allows you to create a fairly complex GDL object of disparate pieces, regardless of the rotation issue.
Richard
AC26 (since AC6.0), Win10
