SOLVED!
SASH OPENNING
mukster
I want to change the sash opening place , without flipping the window, if I flip the window the text and face of the window will also flip which I don't want that or add new window but I did not found the option for this any help?
Operating system used: Mac Intel-based
1 ACCEPTED SOLUTION
Solution
No need to flip the window - the sliding sash is usually on the inside for weatherproofing purposes.
Just mirror the window (left/right) so the sliding sash is on the other side.
Isn't that what you want?
2 REPLIES 2
Solution
Thank you  very much
Setup info provided by author
