SEO is grayed out, can't select, no dialogue box
I'm still baffled. Why won't the dialogue box appear for me, but rather stays grayed out? I have same problem with other files, which suggests an "Unknown Setting" issue.
Subject line says it all: The Solid Element Operations is not working in a file in which I've been using SEO very successfully, and often. Have I inadvertently changed a setting somewhere?
2 Replies 2
Mystery as to no SEO dialogue box, no SEO function. Uninstalled AC and reinstalled, downloading updates, library, etc.
SEO works again.
-JS
The easiest way will be change the work environment profile to any different profile and change it back again, everything will back to normal. It happened to me when i swap from PC to MAC. Not sure why
