‎2006-02-17
08:36 PM
‎2023-05-23
03:31 PM
Rubia Torres
‎2006-02-19 02:55 PM
Scott wrote:I no longer use trim to Roof. Even for when I create a Stair Rail cap from a roof to Trim a wall along a stair.
... I was more interested in why SEO was chosen instead of Trim to Roof to perform the operation. That's all.
Thanks D.
‎2006-02-19 06:12 PM
I no longer use trim to Roof...Often projects are changing and I much prefer to Live SEO as opposed to the Trim to Roof.Jay,
‎2006-02-19 09:00 PM
Scott wrote:I also have switched to SEOs rather than trim to roof since they are more versatile and powerful, and I prefer to support only one method as a standard practice.
Jay Garbarino wrote:I no longer use trim to Roof...Often projects are changing and I much prefer to Live SEO as opposed to the Trim to Roof.Jay,
I must admit I had never thought of modifying walls using a Roof as the Operator Element in a SEO. What a good idea. So the question then is; what possible advantage would there be in using the Trim to Roof command over SEO for walls (other than file size as mentioned), or is the Trim to Roof command really a dead feature? Or further, as a wish, should Trim to Roof be changed so that it is live as well (similar to SEO), or just eliminated?
Thanks for the explanation.
Scott
‎2006-02-19 09:34 PM
‎2006-02-19 09:42 PM
s2art wrote:Yes, I still resort to it on occasion, but is is becoming very rare. It would be nice to have an option to bind the results of SEOs, but would require much better management options.
I usually use SEO now instead of Trim to Roof, but with TTR you can delete the roof and the trim operation remains, handy sometimes.
‎2006-02-20 04:40 AM
Often projects are changing and I much prefer to Live SEO as opposed to the Trim to Roofthere is an option under the wall menu to eliminate the performed trim to roof command and go back to zero....probably i missed the point!!
‎2006-02-20 05:12 PM
Rakela wrote:The live relationships between the walls and roofs eliminate the need to uncut and recut the walls when there is a change.Often projects are changing and I much prefer to Live SEO as opposed to the Trim to Roofthere is an option under the wall menu to eliminate the performed trim to roof command and go back to zero....probably i missed the point!!
‎2006-02-20 05:32 PM
‎2006-02-21 09:28 PM
‎2006-02-21 09:37 PM
But that still doesn't answer the question of why some elements won't trim. I've had the exact same issue 1 or 2 days ago. Erased the roof, recreated it, and everything worked fine. Question is what caused it.Sergio, when your issue first arose, did you double check that you had used the correct type of subtraction method (subtraction w/ upward extrusion)? If not, that may have been the problem.
