2006-02-17
08:36 PM
2023-05-23
03:31 PM
Rubia Torres
2006-02-21 09:44 PM
Scott wrote:Checked everything. Re-SEOed the whole thing a couple of times to make sure the settings were okay. SEOed the wall by both roof planes at once - only one subtracted. Moved roof around, etc. Nothing. And I think I ran into this a while back also and solved it the same way then also (erase roof and redraw/re-mirror).
Sergio, when your issue first arose, did you double check that you had used the correct type of subtraction method (subtraction w/ upward extrusion)? If not, that may have been the problem.
S
2006-02-21 09:55 PM
Matthew wrote:I was trained to use TTR for everything and then I was retrained by the architalkers to use SEO and i would never go back. It does make the file bigger but it is a price I am willing to pay to get the results I get.Rakela wrote:The live relationships between the walls and roofs eliminate the need to uncut and recut the walls when there is a change.Often projects are changing and I much prefer to Live SEO as opposed to the Trim to Roofthere is an option under the wall menu to eliminate the performed trim to roof command and go back to zero....probably i missed the point!!
2006-02-21 10:07 PM
2006-05-31 10:10 AM
2006-05-31 04:13 PM
csparchitects wrote:Solid operations require solid elements. A zero thickness roof is planar.
Just discovered that a roof with zero thickness wont work as an operator in SEO but change thickness to 1mm and it works!
Frustrating / Interesting......
You probably all knew this already
wavydavy@csparchitects
2006-05-31 05:01 PM
Zobi wrote:Like, make up your mind. Insect or fish? Legs or scales?
Might be a bug. That's what it felt like; a fluke.
Thanks to all...!!!
2006-05-31 09:50 PM
2006-06-01 07:47 AM
Zobi wrote:In ArchiCAD 9, I've found that a custom window in a wall trimmed with SEO will refuse to show its GDL defined section attributes properly. TrimtoRoof solved that problem, too. I haven't tested this in 10 yet.
Unfortunately, SEOing a wall really goofs up the windows within the wall.
2006-06-01 07:58 AM
Dwight wrote:I thought a fluke was an invertebrate.Zobi wrote:Like, make up your mind. Insect or fish? Legs or scales?
Thanks to all...!!!
2006-06-01 08:01 AM
