We value your input!
SET ORIENTATION TOOL - REMOVING ANGLES
tsturm
Hello
How do you removed angles from the Set Orientation tool once you have them made?
We have a wing that was set for one angle and now the architect changed the angle. We can program the new view angle easily enough. How do we remove the old angle from the list? How do we get the view programmed or updated in our saved view settings? There is no option tab for this setting? Use the Get Current Window Settings from the top of the Settings window?
Terrence Sturm, Architect
_______________
MBP OSX 10.15.4 Quad Core Intel i7 2.2hz
AC 17 build 5019
AC 22 build 7000
AC 23 build
AC 24 build 5000
2 REPLIES 2
You can not.
The only thing you can do is define 4 new custom angles and they will take the place of the ones currently there. The list always displays the 4 more recently defined custom angles.
tsturm
The work flow would be set the angle to rotate the view. Then program that to the saved view using the Get Current Window Settings to lock the rotation to the view.
I need to make sure the check box at the bottom of the View Settings dialogue is unchecked.
Thanks for the reply.
_______________
AC 17 build 5019
AC 22 build 7000
AC 23 build
AC 24 build 5000
