SPEED UP Archicad
3d conversion with mesh(s) very slow- How can speed for 3d conversion be faster
1. Make sure you are using the opengl engine in the 3d window.
2. Turn off texures in opengl options if necessary
3. Use a marquee to restrict the limit of what is generated in 3d if necessary
Dwight
Adding to Eric:
Build the mesh with fewer nodes.
Most Archicad users neurotically go about replicating contour lines that result in too many nodes/polygons. It is better to sample heights yourself, adding more nodes where it is crucial, using fewer when not.
Dwight Atkinson
