STAIRMAKER
Is it possible to turn off the checking mechanism for stairmaker so that I can make what ever stair I want? AGGGGHHHHHH :!:
thanks,
kc
5 REPLIES 5
TomWaltz
Only if you can do the same to your local building inspector 😉
Tom Waltz
what happens when I need to model an existing stair that was not built under code then??
I may be mistaken, but then again I may be right. If you use Archistair (which they are giving away free) you can make any rise and run your heart desires. Do a search for Archistair and follow the links to get your free copy. Much nicer then stairmaker anyways.
archistair is no longer free....i tried....now $175 US
Brad Elliott
This may be too late to be helpful, but all you need to do is change the parameters. The first thing I do is change the minimum and maximum to 1 and 4 feet. That way I have some freedom to make changes.
Mac OS12.6 AC26 USA Silicon
M1 Macbook Pro
