how to give a object a vertical angel ?
I took the bike of the library. it is in 90° to the ground. I want to use it in a hanging position so I need it in about 75° to the ground. it is possible to change the angel of an object ?Thanks,
Jens
1 REPLY 1
You, have only to insert this row in the 3D script of the bicycle:
roty -75 (this will rotate it by 75 grades)
before this row :
ADDZ 0.71 ! ELSO VILLA
then save it as an obiect file in your loaded libraries
Regards,
Ede
