Save as Library Part not showing
The pull down menu does no longer show the option to save as a library part. What happened?
1 REPLY 1
David Maudlin
Jack:
If you are using an older Work Environment with a newer version, the commands changed (I don't remember when). There should be a sub-menu Save Selection As..., which then lists the library part types (Object..., Door... etc.). So try applying a current WE, or add these commands to your custom WE.
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
