ā2021-07-15 10:32 PM
ā2021-07-15 11:32 PM
ā2021-07-16 04:06 AM
ā2021-07-16 09:05 AM
Podolsky wrote:I'm an Octane user and I like to combine AC line renders and Octane renders so need a camera match.
What do you mean by that?
ā2021-07-16 09:33 AM
ā2021-07-16 09:45 AM
ā2021-07-16 11:10 AM
Podolsky wrote:Unfortunately the 2 point perspective is not supported by Octane (Octane has its own version) so again this needs a workaround. Luckily it's 'just' a matter levelling the camera, increasing the field of view and then cropping to suit.
Camera tool, by the way, is very old. It was not updated for ages (apart of recent update of handling 2 point perspective).
So what happens if you try to render isometric view of ArchiCAD in Octane render? It just not supporting isometric views and you cannot launch it?
ā2021-07-16 11:12 AM
Barry wrote:I'll look into these options when I can. In the meantime I've found that it is possible to copy/paste a bunch of cameras from one scene to another so that helps.
If you change the settings before you place a camera, then every future camera will have the same settings (unless you change them before placing again).
Of course this is only in the one file.
So if you use a template, set the camera and save the template.
However if you have many files, yes you have to set the initial camera up each time (unless you have used your template, then it should already be set).
As there is no such thing as a camera favourite, the best you can do is have a file with a camera set up as you like.
Then you can copy and paste that camera to other files and it will keep the same settings.
It seems you can also save a camera as a MOD file.
Then you can merge that MOD file into any other file and then activate the file path.
It will create a new file path each time you merge and it seems the camera is placed at exactly the same location as when it was saved.
Not perfect solutions, but might be worth a try.
