Showing results forĀ
Search instead forĀ
Did you mean:Ā
Search instead forĀ
Did you mean:Ā
Saved views
Hi! I have a question: Can saved views from a project be merged into a new file?
Thanks
2 REPLIES 2
If you are talking about the content of the view, then yes, you can place Views from one file into another file as Drawings; and Drawings can be placed either in Views or Layouts.
If you are talking about the Settings of the View and the View Map structure (Folders, Subfolders), then no, you can not take a View from the View Map, and place it into another File's View Map.
But you can set the views of your new file to have the same settings.
Meaning the same:
  • -Layer Combination
    -Scale
    -Structure Display
    -Pen Set
    -Model View Option
    -Renovation Filter
    -etc...
If the list of views is too long, try Cloning folders.
I hope this answers your question.
Nando
Nando Mogollon
Director @ BuilDigital
nando@buildigital.com.au
Using, Archicad Latest AU and INT. Revit Latest (have to keep comparing notes)
More and more... IFC.js, IFCOpenShell
All things Solibri and BIMCollab
Thanks
