Scanned floor plan to 2d/3d anyone
So I dont want to pony up $ 900 for Plan2model, is there a decent way to convert a scanned in floor plan image file into 2D walls? Without tracing over every little detail.
1 REPLY 1
Dwight
Depending on the scale of the scan and its accuracy, you'll find that having a helper shout out the coordinates from drawing dimensions as you input the walls is the fastest and most accurate way to go. In view of the fact that drafting is often fudged.....
Then position windows using the absolutely correct wall placement with the scan underlaid, again using the dimensions to position.
Dwight Atkinson
