Scans not printing
Hi Guys:
I have placed a scanned image in my floor plan and I want it to print, but it is not.
I dragged it in, it did not print and I brought it in as an external drawing fil and it did not work....
Any Ideas?
Thanks
Jess
10 Replies 10
TomWaltz
Did you place it on a layout? Or are you trying to print from the plan window?
Tom Waltz
Both ways do not work.
TomWaltz
What version of Archicad and what OS?
Tom Waltz
Well it is AC v.10
Windows
I got it to print- I put it on the title block directly, as opposed to placing it in the layout on a layer and printing, or then putting on title block in layout and printing.
AND- I think my problem may have been that it was a PDF?
Does that seem like it would be a problem?
Thanks.
Argh.
SO i guess I can print to a printer but not to a PDF.....
Thanks.
The ability to place PDF files is a new feature, so that may be the problem. If so it should be reported as a bug (easiest way is to launch the Bug Reporter that is in the ArchiCAD folder).
In general I would not use PDF format for straight bitmap images (such as a scan) JPEG and TIFF are simpler formats with a longer history and thus likely to have more predictable behavior.
David Bearss
I have had a similar but different problem with plotmaker 9. I have had good luck placing png images of my engineering sketch details in plotmaker rather than jpg. They appear wonderfully in my pdf files and print nicely on my DesignJet. However on occasion when sending pdf files to a print service for printing, the png images drop off. Recently had a project in for permit review and the plans examiner was wondering where the shear wall schedule was. In opening my pdf of the permit set the schedule was on several sheets but dropped off when printing. never found out from the Print service why.
David Bearss
Archicad 28/Windows 11
Alienware 17 R5
i7 2.4 GHz / 16 GB ram
Over the years I have also seen sporadic problems with embedded bitmaps, but not lately. I had hoped they were a thing of the past
So- Further more, The whole thing ended up being a PITA.
I was able to print to a printer my layouts with images on them.
I was not able to print to a PDF ever, after all.
How ever- I just went and checked a Publisher set I made, with teh PDF formating, and tah-dah- the images are there.
I do NOT understand. But, for anyone else that is having tis probalem, this is one way around it.
Publish to a PDF instead.
