Showing lines in 3D view
hi all, is there a way to make a line drawn with the like tool show in
the 3D window? I am trying to build a wireframe model, but the lines are not showing in 3D space
any ideas or suggestions
thanks 😃
11 Replies 11
TomWaltz
Nope.
You might be able to make a super thin beam (1/64") and stretch it around.
Tom Waltz
Steve Jepson
thanks 😃
this is probably a dumb question but did you try to just view the model in wire frame mode?
Steve that is defiantly not a dumb question, and the answer is no.
I don't know how to switch modes. Will wire frame show 2d lines?
You can't view 2D AC lines in 3D views. You can view DWG files in 3D, however, so maybe you can convert your lines to DWG, attach the DWG file, then view. I have read it somewhere here, try a search.
Steve Jepson
lines are not 3D so the answer is no.
however, you can make walls beams, columns, what ever as small as you like if you are wanting to draw the wire frame of something in 3D mode.
If it is just that you want to view your model in wire frame mode that is just click "Ctrl+Shift+F9" or change your settings by clicking View-3D View Mode-3D Window Settings.
The secret is to use the Internal Engine rather than Open GL mode.
You may also find it useful to convert your 2D lines into someting 3D using the magic wand. Then you you can see them in 3D.
What is it that you are making?
Link
Now this is an occasion where copying a flat marquee from the 3D window to another window would come in handy!
Link.
Steve Jepson
thank you all for your help and support.
I am trying to build a wireframe model of a tower I we are working on. the wireframe model will serve as the underlay for architectural space planning, then by used for structural analysis.
Habi
Dwight
I attach an archive with two 3D line objects, one established by angle slope and the other by separate elevations.
Dwight Atkinson
