All Library parts on plan
Hi guys,
i remembered somewhere i saw the way with a command to put all library parts on the plan.
It was at the special menu, but where exactly and how it works.
I have made the special menu but no all the submenus.
Thanks for the help
3 Replies 3
O.k. the command is in the Special menu, I put it on the menus but nothing hapen when i select it
Steve Jepson
You can create a Container with all of the objects in you plan in it.
Is this what you were thinking of?
Perhaps you just want to create an archive file? .pla ?
Did you figure out how to do what you want?
Link
tsikospan wrote:
Hi guys,
Thanks for the help
Firstly, follow Karl's instructions here to make the Special menu appear correctly.
Then use the Place All Objects command, which will allow you to select the subtype of the elements you wish to place.
You could also try a Search on the topic, as it has been discussed a few times already.
Link.
