Room Accessories
Craig Bagley
I'm using AC9. I try to use the Zone Tool and Room Accessories to apply wall base to rooms as part of a residential remodel, and the results are disappointing: wall base on some walls, not others, wall base applied across door openings, and extending slightly beyond corners where walls jog. I've tried it on more than one room; the results seem to be consistently INconsistent. The Zone boundaries seem to be in the right place. I'm using Extras>Interior Wizard>Create Room Accessories>Wall Accessory>Moldings and Panel SE9, and turning off everything but the base molding. What am I missing?
AC27 USA/Build 5030 16" MBP
1 REPLY 1
Steve Jepson
I am sure you are going about it the right way, however, until someone helps you out with that, you could use other methods.
Are you familiar with the Profiler tool?
Would you like to make a 3D base object with the profile you need that you can place along the wall and then stretch between the casings?
Depending on the profile of your base trim you could use a wall for the base trim.
