ā2005-11-10
11:08 PM
ā2023-05-25
05:15 PM
Rubia Torres
ā2005-11-11 03:04 AM
ā2005-11-11 03:31 AM
ā2005-11-11 04:03 AM
Peter wrote:I'm not disagreeing with you, Peter. I understand what you are saying. It
Stuart,
If Archicad is drawing a two point perspective then what you are saying is exactly true. But if Archicad is drawing a true four point perspective then wouldn't the walls taper closer together upward from the eye level line and taper together downward from the eye level line ?....
From what I have learned about true perspective and what looks right to my eye and is to me logical, AC should, in the case of eye level and target level being equal, draw the edges tapering in both directions from the eye level.
Peter Devlin
ā2005-11-11 04:22 AM
ā2005-11-11 04:38 AM
ā2005-11-11 04:39 AM
ā2005-11-11 04:43 AM
ā2005-11-11 04:48 AM
ā2005-11-11 04:53 AM
Peter wrote:And what was your margin or error, about +/-0.02degrees?
Stuart,
I downloaded Bob's jpg and pasted as a figure in AC.
I tried to trace as carfully as I could the left and right corners.
The left and right corners are not parallel.
See attachement
Peter Devlin
ā2005-11-11 04:58 AM
