mukster
Scissor trusses with a raised heel
Is it possible to make a scissor truss with a raised heel? It is necessary over a heated space I also cannot figure out how to adjust the overhang lengths.
Archicad 23 on a MAC platform,
3 Replies 3
Hi Mukster,
You can use the TrussMaker to create custom trusses.
DGSketcher
Legend
You can draw the truss as a complex profile and the place it using the beam tool with a short (extrusion) length equal to the timber section width, assuming it is rectangular timber.
mukster
Or you can use the Truss Pro object and specify heel height and scissor pitch
