Section, Elevation, Detail - window size
This may have been answered somewhere - even in the manual - but I can't seem to find it anywhere. Does anyone know what the default size and position for a section / elevation & detail window is? Meaning - when you first open a section, elevation or detail, what decides the position of the window on the screen and it's size.
It's really quite annoying when you open a section window and it's title bar is up behind your palettes. And if you have to drag and resize dozens of them, well......
I'm assuming it's an internal ArchiCAD default and uneditable, but just wanted to ask in case there is somewhere where this can be customized.
This thread might help you. Check out Karl's explanation half way down.
Thanks Stuart. This helps for keeping window sizes after you've resized them. I was actually wanting to know about what dictates the position and size the first time you open them
