2008-07-17 05:27 AM
2008-07-17 06:12 AM
2008-07-17 06:25 AM
2008-07-17 07:06 AM
2008-07-17 06:12 PM
Jeff wrote:IMHO, one should "never" (never say never, so 99.9%) change the value of Magnify from 100%. What you've experienced is what is supposed to happen. Magnify magnifies or shrinks, ignoring any other scale. The only time to use it in my opinion is when placing 3D drawings or images or perhaps text PDFs that are not to scale and you want to adjust them visually to fit the paper.
I'm using the "Built-In Section Marker".
And, yes, the site plan is published at 50% or 1/8" scale. The View is 1/4" scale.
But, I can't change the site plan to a 1/8" view because all the topo info is at 1/4" and anything I want to appear on both plans get messed up when I switch between views.
Maybe I have been working the wrong way on this project? What do you do?
2008-07-17 06:35 PM
2008-07-17 07:14 PM
2008-07-17 07:29 PM
Jeff wrote:This used to be an issue in the days before you could "place" a drawing. If you are opening a DWG or importing it you need to set the scale to the correct final ratio BEFORE you open or import.
Yes, the topo text size and alignment gets all messed up when I change scale. It was imported as a DWG.
2008-07-17 08:03 PM
Chazz wrote:True. Last dwg I did this too worked, because the text anchors happened to be in the right spot. Not to be expected though.
(after reading Karl's post....) The problem with the find-and-select method is that it can shift the position of the text. Reimporting will get it spot on.
2008-07-17 11:57 PM
Karl wrote:I find that ever since my 500th post and the conferring upon me the new title of Veteran Member, these things just come to me.
Great tip....Chazz!
