2006-05-30 08:58 PM
2006-05-31 09:16 PM
Aussie wrote:What do you mean? Do you mean just cut it and paste it so the exact same wall goes in the exact same place?
As a test cut and paste one of the errant walls - sometimes a corruption can set in. Select the dimensions as well if you want to keep them too.
2006-05-31 09:25 PM
Ted wrote:I checked duplicates and the only things that came up was a couple of labels on one duplicate object that was in working areas completely away from the floor plan where the problem is arising.
Check to see if you have duplicate parts. Duplicate parts in same spot do not show in section/elevation and any associated dimensions that were added in section/elevation window to parts prior to duplication disappear too.
2006-05-31 09:36 PM
2006-05-31 09:37 PM
