Sandramuller
Sections - from model or change to 2d?
We had a conversation in the office.
For tender/construction drawings, how much do you fix the section (after you changed from just grey walls floors etc to showing  the build ups) and how much do you transfer this information  in a 2d drawing (and finish it  off in 2d like you would have done in Autocad)?
Any example images would be nice
18 Replies 18
Tim Ball
I've been working with 3D only for nearly 10 years
See this example from 8 years ago
https://bobrow.com/archicad-working-drawings-done-without-drafting-details/
Tim Ball
AC26, iMac
User since V5
Eduardo Rolon
Don't forget that you can create 2D Patches for critical conditions then copy/paste them as necessary. A very old tool that can get you out of a jamb quickly to overlay on top of 3D.
https://help.graphisoft.com/AC/26/INT/index.htm?rhcsh=1&rhnewwnd=0&rhmapid=#t=_AC26_Help%2F040_Eleme...
Eduardo Rolón AIA NCARB
AC29 US/INT -> AC08
Eduardo Rolon
You should avoid doing that but if you must then it is easier to just copy the elements in section/elev and move them to the side so that you can still see what changes automatically.
Still this is not the way you should be using AC, you will most of the benefits of working with BIM.
To make it more clear any example file I received from someone asking for work which "unlinks/explodes" sections elevations just indicates that the person is in serious need of training.
AC29 US/INT -> AC08
jl_lt
Ace
Hi.  The first advice i can think of is simply avoind doing that as much as possible. You are better off drawing in 2d software than in Archicad if you are into that workflow (nice video anyway)
Second advice would be to leave out all preconceptions you have from drawing in 2d. You are now in a 3d bim software; it would be in your best interest to adjust your mindset because workflows and ways of doing things are completely dfferent here. I have found that the "i will model and do things so they resemble to what i did in 2d" mindset is specially pernicious.  2d cad had its own flow, the same as Archicad has its own. Embrace it. Eventually youll arrive to a point when theyll look even better than in 2d cad.
Third, one of the benefits of using Archicad is that everything is completely coordinated (assuming you model in 3d). Sure, the speed of clicking is much slower thatn in 2dcad, so you might think you are not doing much. But one Archicad click is about 10 2dCad clicks, because once you have some standards and template more or less set, you are almost always advancing forward. No need to go back and check things.
Finally, here is a short article from Archicad guru James Murray, from Onland.info.  In its day, It really helped us in getting in to the Archicad workflow and still go back to it from time to time:
https://www.onland.info/archives/2006/03/beauty_is_third.php
Best of lucks
Sandramuller
Graphisoft Hotline has suggested that a few times when they could not fix things.
Just not sure how this would ve useful as a strategy for a whole.section
Sandramuller
I agree. There is a lot they don't seem to know.
DGSketcher
Legend
With the digital design process users tend to loose a sense of scale. Possibly the best way to learn is to print the drawing and consider how much of what was drawn is still visible. There is little point in showing detailed features when they can’t be seen in the output.
Eduardo Rolon
Patches are used when all else fails to clean up a specific condition so I am not surprised that they recommend them. If you are modeling correctly you should only have to use them very rarely. IIRC last time I did was in a 2017 project and before that in a 2008 so you would not build a section with multiple patches. If you are having to do that then you are using AC wrong. 😉
Anyway you have received comments from a lot of users here, all have recommended not exploding to 2D but you use the software as you want, they are your projects.
FWIW, all 3D except the hook
AC29 US/INT -> AC08
mthd
Please take a look at the excellent videos online from Robert Mann if you are in Australia on how he goes about it. He also uses the complex profile tool to assist in the process. I am also trying to learn how to use the complex profile tool so that I have to do less 2D line work on my sections. I turn my sections and elevations into drawings when the Cad Image generated roof coverings and capping happen to jump out of place at times lol.
Edit: This excellent video by Jared Banks shows a master class of how to mainly use 3D elements and do minimal 2D work on sections and details.
https://youtu.be/uCqFJ70v-xM
Edit 2: These are just principles of how to get to the end result of great looking sections elevations or details. I would use what helps me to get the job completed in time and what tools and skills I have available at the time. If you happen to have Autocad in the office and are a proficient user then it’s cool to use a different method to complete your work on time. Most of us here try and build an accurate 3D model to present to clients and then extract as much BIM from it as is possible. All good fun.
I used to use Brainy CAD with my hands in the previous millennium like many older ones here did as well. I am glad we have CAD because I can’t see as well these days and my tendons in my fingers are too tight for precision drawing lol.
AC8.1 - AC29 ARM AUS + CI Tools
24C GPU 7.8TF 32GB RAM OS Sequoia.
