2009-06-30 05:32 PM
2009-07-02 03:12 PM
Krippahl wrote:
As I teach VB at an architecture university for 5 years now, the problem of not being able to extract perfect looking drawings from the model has been discussed many times, with students and colleges.
I also design, so I totally understand the need to communicate clearly ones intends, and also the price of poorly coordinated drawings
Here are my 5 cents:
- Drawing is more flexible than modeling, so there is always stuff that takes much more work to represent correctly on the model than in a flat cad drawing.
- You can model practically everything to obtain "perfect" drawings, but the longer it takes to do the more money you loose.
- For the same amount of effort, 2d drawings are probably better looking than 2d from a model.
But:
The clarity of drawings you may loose from doing a 100%model derived drawing is largely compensated by the coordination and correctness you get from it.
So, if the choice is between pretty drawings that are based on paper and pen conventions from last century or correct drawings, I think this is a no brainer.
As long as the constructor understands our intend, you should not go any further in trying to perfect the looks of your drawings, especially if this will rob work hours from the job you where given: designing.
James Murray explains this much better, as usual:http://www.onland.info/archives/2006/03/beauty_is_third.php
2009-07-02 03:37 PM
Steven wrote:To me, the definition of "good looking" drawing, is that they will communicate the design well. The clearer the intent can be made, the better. And line hierarchy, good graphics, and orderly layout all work to that end. It is easy for stuff to get missed, particularly where a lot of the guys doing the building don't read english very well. It's been my experience that graphically good drawings help with the agency submittal process as well. As far as clarity, but also in the confidence that the plan checker has in the designer. There have been times that the code official has commented "Good looking drawings" and this made over the counter plan check go much faster (and one would assume internal plan check as well)
Very well put. I think the problem comes from working for architects who were taught and use these "last century" drawing techniques; they are harder to persuade to change to these newer ideas. I think I will slowly, piece by piece, change to 3D and see how it goes...
Thanks for all the thoughts.
2009-07-02 05:31 PM
2009-07-02 06:20 PM
svenl wrote:So, do you do your drawings 3D or 2D??Steven wrote:To me, the definition of "good looking" drawing, is that they will communicate the design well. The clearer the intent can be made, the better. And line hierarchy, good graphics, and orderly layout all work to that end. It is easy for stuff to get missed, particularly where a lot of the guys doing the building don't read english very well. It's been my experience that graphically good drawings help with the agency submittal process as well. As far as clarity, but also in the confidence that the plan checker has in the designer. There have been times that the code official has commented "Good looking drawings" and this made over the counter plan check go much faster (and one would assume internal plan check as well)
I've always prided myself on generating good looking drawings, but as I work through my first project in Archicad, I'm seeing the advantages of this system. It'll be interesting to see how this pans out.
2009-07-02 07:46 PM
Steven wrote:Not sure what you believe is "lacking" in these graphics. And I'm pretty "old-school." (I was using a slide rule in my first structures class, if that tells you anything.)
Looks good, but I don't know if the graphics would "fly" with the computer illiterate principals here...
2009-07-02 08:24 PM
2009-07-02 08:44 PM
Richard wrote:And I'm too young to know what a slide rule is!Steven wrote:Not sure what you believe is "lacking" in these graphics. And I'm pretty "old-school." (I was using a slide rule in my first structures class, if that tells you anything.)
2009-07-02 08:50 PM
splitlid wrote:Some did.
dinasours have the best knowledge but they must keep up.
they died in the end.
2009-07-02 09:35 PM
2009-07-02 10:30 PM
Steven wrote:This is a false dichotomy. Most sections that experienced ArchiCAD drafters produce are 3D with a little 2D "touch-up" overlaid on top. And frankly, in a small scale section, too much detail is inappropriate -- and showing just the appropriate level of detail is very "old school." Small scale sections should just be referencing the larger details, and maybe showing critical vertical dimensions. Insulated headers, anchor bolts, etc. are more appropriate for maybe 1"=1'-0" (1:10 metric) details or larger scale.
Really though, the "covered porch section" is not showing eave details, has line weight problems, and generally does not look as good graphically as the line drawn section. We show strapping, anchor bolts, flashing, rebar, actual window DWG's, insulated headers, perimeter & underslab drains with crushed stone, etc. etc. etc.
