Select connected lines
C_Gold
Hello everyone,
Is it possible to select contiguous lines at once in Archicad? In Revit this works via the tab key. I have an imported site plan where I want to highlight the line thicknesses of individual buildings but without always having to select the 4 individual lines of the rectangle.
Best regards and thanks in advance !
2 REPLIES 2
Ricardo Lopez
Unfortunately it is not the same approach that Revit has, as you can read in this post: https://community.graphisoft.com/t5/Modeling/How-i-can-select-chain-of-lines-in-archicad/td-p/187368
Regards. -
M. Arch. Ricardo López
It depends how they have all been drawn.
If individual lines with black hotspots - no.
If they were drawn as a continuous line and have coloured circle hotspots, then they are part of a group and can be selected as one when grouping is enabled.
It is possible to magic wand a continuous line over connected individual lines.
These will be grouped and can be selected as one, but of course you also have the original lines.
I just remembered there is also a 'unify' command.
But you have to select all of the lines in the first place - which is your issue.
But once selected you can either group them or unify them.
If you unify, they will be changed to a single polyline.
Setup info provided by author
