How i can select chain of lines in archicad?
Hi , i want to know how i can select chain of lines or group of lines without have to make grouping
to make my question more clear, in revit: i can click on tab and then instead of select one line it select all the lines connected to this single lines.
I usually use the method of group and suspend group but if there is better method you can tell me on it that will be great.
ArchiCAD does not have an equivalent to this Revit function (except in the MEP add-on). You should be able to use the marquee in combination with Find & Select to accomplish the same thing though. This is nearly as convenient as the Revit function and far more versatile.
