FWIW, this problem persists after the 2325 hotfix.
Played around some more and noticed that if you select an item (e.g. a wall) in 3D and then edit it, it will appear deselected in the info box. But you can still bring up the wall selection settings with a keystroke, and then edit it from there.
But there's a caveat: when you bring up the wall selection settings, they will be set to the "Default" wall settings.... instead it should give you the actual info for that particular wall.
It's a real mess, and in my opinion this should be a big priority for the next hotfix.
edit: this problem only happens for me in the 3D window, not in the 2D plan.
AC 21 (8002) & 22 USA
Mac OSX 10.14.5 on MacBook Pro 2.3GHz Intel i7, 16GB Ram, NVIDIA GeForce GT 750M 2GB VRAM, 500GB SSD
