Selected items in 3D don't stay selected after editing
Does anyone know why anything i select in 3D will not stay selected after I make a change? I have to reselect in order to make more changes on the info box. This did not happen in AC11 so maybe it is a preference that I am missing?
11 Replies 11
Erich
I am getting this too, even after the last hotfix. It would be great to have this fixed or to know where the correct setting is if I am missing something.
Erich
AC 19 6006 & AC 20
Mac OS 10.11.5
15" Retina MacBook Pro 2.6
27" iMac Retina 5K
yep, still getting that, it's a "feature"!
Eduardo Rolon
Maybe I am missing something but mine stay selected. Anyway, Undo and Redo can be used as a work around AFAIK.
Eduardo Rolón AIA NCARB
AC29 US/INT -> AC08
If Burghitect(no sig) is Mac, then so far only mac posters reporting this?
All ok here.(pc).
Bier
Eduardo Rolon
B,
I am using Os X and it is working fine. But I am in 10.5.5 and he might be using another version or probably Windows ME, sorry Vista.
AC29 US/INT -> AC08
hmm that's interesting about 10.5.... it may be related i guess
regardless... this has been a complete grind for me today... and it's not limited in 3D window (actually often when in 3D things work better) it's happening on plan: i select something and holding shift i wanna add to my selection, i get the pause/beachball and it may or may not work; i try to pick up properties and because it's sooo slow pausing etc it ends up selecting rather than picking up properties; i zoom in and out and although whatever i selected appears selected, the info box is empty!
I am using a Mactel with OS 10.5.5. it also happens in section/elevation views.
This happens to me in plan, section, elevation, and 3D. I didn't notice until I'd installed the hotfix. Before that, I didn't yell at my machine nearly as often, so I'm assuming that the Info Box maintained the info for the selected item before the hotfix.
Just trying to be more like Revit 😉
