Selecting Different Elements & Changing All to One Layer
Is it possible to select different element types (walls, Slabs, Lines or circles....) and change their default layers all to ONE specific layer all together in one action vs. doing one by one?
Thanks,
Joseph Harouni
8 Replies 8
Link
Edit Selection Set from your Edit menu. Ctrl+Shift+T by default. It's also the little hammer thing you see next to the Layer Name in your Info box when you have elements selected.
You can also change their pens.
How's that?
Link.
Thanks,
Joseph Harouni
Maybe you should try Options\Layers\Active layer.
See the Manual on how it works.
Laszlo
SeaGeoff
Ace
I recently discovered the little hammer much to my delight. But while we’re on the subject, can someone please explain why we can’t simply select multiple objects types and change their layer in the info box?
Thanks.
Regards, Geoff Briggs
I & I Design, Seattle, USA
AC7-29, M1 Mac, OS Tahoe
Graphisoft Insider's Panel, Beta Tester
__archiben
Thanks.
i would imagine because the info box relates specifically to one tool at any one time. the 'edit selection set' dialogue addresses the basics of multi-tool elements.
maybe when GS implement a fly-out 'settings' dialogue ala autoCAD 2004 from the tools palette, the 'info' box can be done away with in its present incarnation and become a development of the 'edit selection set' and element information . . .
~/archiben
b e n _ f r o s t
SeaGeoff
Ace
yes, but how about the selection tool?
...the 'info' box can be done away with in its present incarnation and become a development of the 'edit selection set' and element information . . .
I'm not familiar w/ A'cad '04 but I definitely agree with incorporating the element info into the info box. Start, end, length, angle, etc. should become editable fields.
Where can I find the hammer?
David Maudlin
Zeelrich:
The Hammer was removed from the Info Box a while ago so the layer name pop-up could be longer. Just use the Edit Selection Set... command.
David
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
Stress Co_
I was so accustomed to using the icon in the Info Box that,
when it disappeared (c.AC20), I added it to my custom toolbar.
Marc Corney, Architect
Red Canoe Architecture, P. A.
