hide an element
I have some morph elements in my project. I want to hide one of them but when I hide the layer all of them will be hidden. how can I hide just one element without hiding the layer ?! I will appreciate if any one helps me
Hello m_aalaei,
The first solution is to create another layer to put it on it.
3D view
You can select all your project except the morph you do not want and do a right clic to select the option : "Show selection in 3D"
2D view
You can create a pen set or a graphics override to mask your morph by a white apparence on a white background. You can find these function by the menu "Documentation".
Either you can change the morph 2D parameters by modify these options :
By this last way you are able to mask a element which is above your cutting plane.
Christophe - FRANCE
Formateur Archicad indépendant à NANTES
Archicad 15 to 29 FRA FULL
thanks for your reply Christophe I will try it.
