Shift selecting will always add to the selection if the element is not yet selected, or remove from the selection if the element
is
already selected. Furthermore if you are not in the Arrow tool when you are selecting, the Info Box will only show how many of the
last
selected elements you have. So if you are in the slab tool, and have three slabs selected then shift select a wall, the info box will only show 1 wall selected even though you have three slabs selected as well. This is a little confusing at first but is quite a neat feature once you get the hang of it.
Let's say you're in the Arrow tool and you 'swipe' over three slabs and a wall and the Info Box shows the Wall tool with 4 items selected. If you want to edit just the wall, you can click on the Wall tool in your info box and once opened the dialog will say Selected: 1 Editable:1, so you are only making changes to the wall, not the slabs (even though they are selected). You could also double click on the Wall tool in the Toolbox to get to the same settings.
Similarly, if you have the same four items selected and the wall tool is active in the info box and want to edit the slabs, could just double click the Slab tool in the Toolbar. Or you could just shift select the slab to remove it from the selection, shift select it again to add it to the selection. Doing that will make the slab tool active in the info box, so you can edit the slab settings from there.
I would recommend escaping out to your arrow tool and then do your selecting. In the Arrow tool, the info box will show
all
the elements you have selected. And, the info box will change to show the last selected item, but the numbers will remain accuurate for the total amount of selected items.
Hopefully that was more helpful than confusing. I'm hanging over a little today after Chritsmas celebrations.
Link.
