Selection tool - entire elements - missing feature
Hi.
Im using the select entire elements with swipe right or left a lot together with the magnet deactivated and I think it's a great feature. But it does not work selecting doors or windows for example in a walls. Is this a bug, Im doing something wrong? This would really make my day more efficient.
Regards
Alexander
Erika Epstein
No, not a bug, that is how Archicad works.
There are many ways to select elements in Archicad which is one of its strengths.
If you want to select multiple windows/doors, rather then selecting them individually (aka hunt & peck), use the command to select all, ctrl/cmmd + A.
If you only want to select them within part of your design, you can draw a marquee around the area, activate the window or door tool, then select all, ctrl/cmmd + A.
Erika
Architect, Consultant
Mac OSX 10.11.1
AC5-18
Onuma System
Yes, I agree that's one of archicads strengths. I usually use the marquee + tool selected + ctrl A but it would be way faster to just use the select whole element marquee. I find it strange that it works with objects, walls etc but when you put a window or door in a wall it doesn't consider it as an object...
