Setting new "centerline" of wall comp?
can i permanently set a new "centerline" of a wall composite?
I am working with a very particular grid and i need to offset the "centerline" off from what it is, and not the true centerline.
I found a setting that allows me to do so, but I am hoping that I can fix the offset in a more permanent spot.
Thanks again!
the reason i am doing so, is so that my 2x6 walls, and 2x4 walls line up a certain way, on the centerlines of a working grid.
1 Reply 1
You can save the settings as a favorite.
