Martin Walter
Setting standard value for Reveal to wall core
Where can I set the standard value for Reveal to wall core?
When I insert a new window, the value is always 0 for Archicad 23 INT and 0,255 for Archicad 23 GER.
AC22-27, Windows 11, i7-1355U, 32GB RAM, 2TB SSD
It should remember what you last set the value to and use that the next time you place a window.
It should remember the last value set when you save the file.
So you may want to reset and save your template.
Also if you use the favourites, this reveal distance will be saved with each favourite (so it can be different for each type of window).
