Setup List Schemes
I've been reading the Calculation Guide.
Does someone know where is the Setup List Schemes dialog.
I am referring to Page 57 in the Appendix.
It seen like it is different from ArchiCAD 15.
4 Replies 4
You have to customize your Work Environment to add the various Calculate menu items to your menu structure. None are present in the standard menu schemes.
AC 29 USA and earlier   •   hardware key   •   macOS Taho 26.5 MacBook Pro M2 Max 12CPU/30GPU cores, 32GB
Option > Work Environment > Work Environment > ???
Can you tell me how to go from here?
It's make not sense to me what is describe in the Calculation Guide.
Customizing menus has nothing to do with the Calculation Guide ... it is in the User Manual.
See the attached screenshot. Create a new menu as shown and drag and drop the Calculate menu commands into it.
Thank you.
Now I can continue my Calculation Guide.
