Shell tool used as roof? How to make the "edges" perpendiclr
rob2218
see attached.
i>u
Edgewater, FL!
SOFTWARE VERSION:
Archicad 22, Archicad 23
Windows7 -OS, MAC Maverick OS
8 REPLIES 8
Dontknow
Found som info on the matter:
Roof/Shell Edge Listing Parameters
But it looks like it doesn't do anything to the shape of the roof.
Architectural construction designer, draftsman, modeller
ArchiCAD 25.
rob2218
thanks for the link.
I'll look at it right now....but...what's the point with all these "settings" if the edge shape doesn't change? What's up with that?
i>u
Edgewater, FL!
SOFTWARE VERSION:
rob2218
OK..read the dern article....and you are correct...doesn't seem to do anything to the "shape" of the edge I'm referring to. what's the point with all these settings if they don't don anything?
i>u
Edgewater, FL!
SOFTWARE VERSION:
Dontknow
Been wondering the same thing. What's the point of it.
You could put a morph against it to achieve the result.
ArchiCAD 25.
David Maudlin
Rob:
You can view the Shell in a Section, then add a node to Its Profile line to alter the edge.
The Edge Setting is for listing only (so quantities can be summed for Eaves, Ridges, etc.), similar to the Roof Tool.
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
sinceV6
Hi.
You could also extend the profile -with the same slope- and then define a contour in floor plan to its original extent. It should cut it like you need to.
Best regards.
Dontknow
David wrote:
Rob:
Oke, I did some experimenting.
Is this what you mean: video ?
ArchiCAD 25.
David Maudlin
Yes.
