‎2018-07-02
03:25 PM
‎2023-05-19
10:08 PM
Gordana Radonic
‎2018-07-02 04:22 PM
‎2018-07-03 12:20 AM
Barry wrote:I'm sure you can do that using column, but actually I don't want to heap up. Also if I change the angle between walls, you must change the column profile, which is unfavorable. Sure there is more easy way to do that.
If that doesn't work then creating a complex profile column for the corner and butting the straight walls up to it should work.
‎2018-07-03 03:43 AM
