‎2004-10-09
07:13 AM
‎2023-05-26
03:21 PM
Rubia Torres
‎2004-10-13 01:36 PM
Don wrote:Same with us. We were told the documentation was back-ordered. Maybe that is the same with you.
I just upgraded from 8.1 and was sent cd's and upgrade codes, but no new manuals.
‎2004-10-13 02:36 PM
‎2004-10-13 02:46 PM
Jeffrey wrote:You can set this up with through the Work Environment dialog, under keyboard shortcuts. You can see all of the commands by selecting List All Commands in Alphabetical Order. If you use Zoom and double click on any spot it zooms centered on that point, or you can click and drag a box to zoom. The Special Zoom command works similarly to the mouse wheel (which is far and away the best way to go, I am completely lost if I move to a non-wheeled mouse now) anyway you click any point and by dragging up or down you zoom in or out centered on that spot.
The one command that doesn't appear to be available is the good old zoom as you get by selecting the magnifying glass at the bottom of the window, the "new" zoom is rather beat as it zooms to the center and not to where the cursor is placed as it does with the mouse wheel which isn't always available.
‎2004-10-13 10:12 PM
