Shortcut Keys in 9.0
You know for all the complaining about the manuals I did use and read them. I realize it's a money thing, but for all that AC costs I resent having to print out my own manuals.
When I go to the AC help button and look up keyboard shortcuts, it tells me "from the left hand list window......". Where is that located?
Thanks,
Don
13 Replies 13
Stephen Dolbee
Don wrote:
I just upgraded from 8.1 and was sent cd's and upgrade codes, but no new manuals.
Same with us. We were told the documentation was back-ordered. Maybe that is the same with you.
Steve
AC19(9001), 27" iMac i7, 12 gb ram, ATI Radeon HD 4850 512mb, OS 10.12.6
kevin b
We got the CDs and codes from our reseller and then maybe three or four days later got all the documentation direct from Graphisoft.
kevin s burns, AIA
massachusetts, usa
AC25 (1413), since AC6
Windows 10
kevin b
Jeffrey wrote:
The one command that doesn't appear to be available is the good old zoom as you get by selecting the magnifying glass at the bottom of the window, the "new" zoom is rather beat as it zooms to the center and not to where the cursor is placed as it does with the mouse wheel which isn't always available.
You can set this up with through the Work Environment dialog, under keyboard shortcuts. You can see all of the commands by selecting List All Commands in Alphabetical Order. If you use Zoom and double click on any spot it zooms centered on that point, or you can click and drag a box to zoom. The Special Zoom command works similarly to the mouse wheel (which is far and away the best way to go, I am completely lost if I move to a non-wheeled mouse now) anyway you click any point and by dragging up or down you zoom in or out centered on that spot.
kevin s burns, AIA
massachusetts, usa
Windows 10
Thanks everyone! Now I'm zoomin' along once again.
